so I have been having performance issues I can creep up mph, but if i floor it around 4500 it bucks then goes for a second then bucks again so the day before cleaned and checked and cleaned coilpack connectors, and injectors, and took it for a test ride same thing going on. today I cleaned maf connector, and tps connector and checked to see if voltage was correct on tps it was at .38 vdc throttle closed so i adjusted it to .45 at closed throttle and 4.09 vdc at wot now the car will not start. so for know i disconnected battery and I will connect back in 15 min to see if the ecu needed to be reset any suggestions
